Something is very wrong. Script errors.
Nickman
Post by Nickman »
I just started using EventGhost and I must be doing something wrong. Every action I try to add just gives me errors.
For example:
Add Action -> System -> Start Application:
  File "C:\Program Files\EventGhost\eg\Classes\ButtonRow.py", line 108, in OnOK
    self.parent.OnOK(event)
  File "C:\Program Files\EventGhost\eg\Classes\TaskletDialog.py", line 161, in OnOK
    self.DispatchEvent(event, wx.ID_OK)
  File "C:\Program Files\EventGhost\eg\Classes\TaskletDialog.py", line 122, in DispatchEvent
    self.__processingChannel.send(wx.ID_OK)
TaskletExit
Add Action -> Window -> Find a window:
Exception TaskletExit: () in <generator object __iter__ at 0x066B4710> ignored
  File "C:\Program Files\EventGhost\eg\Classes\ButtonRow.py", line 115, in OnCancel
    self.parent.OnCancel(event)
  File "C:\Program Files\EventGhost\eg\Classes\TaskletDialog.py", line 166, in OnCancel
    self.DispatchEvent(event, wx.ID_CANCEL)
  File "C:\Program Files\EventGhost\eg\Classes\TaskletDialog.py", line 120, in DispatchEvent
    self.__processingChannel.send(False)
TaskletExit
  File "C:\Program Files\EventGhost\eg\Classes\MainFrame\__init__.py", line 344, in FuncWrapper
    func()
  File "C:\Program Files\EventGhost\eg\Utils.py", line 176, in Wrapper
    eg.Tasklet(func)(*args, **kwargs).run()
TaskletExit
Maybe I'm missing a plugin. Loaded plugins:
Microsoft MCE Remote
XBMC
Task Create/Switch Events
I've tried to install different verions, including the latest 0.3.7.r1436. I have Windows 7 32-bit and a MCE remote. The remote is working and I can use it in XBMC.
Nickman
Re: Something is very wrong. Script errors.
Post by Nickman »
I haven't done anything and now every script is working and I get no errors at all.
I have no idea what was wrong before.
