Hi folks!
I thought that "Enable exclusive" disables the specified folder, when focus is lost. But this is not the case. To me it does the same like "Enable". So an extra macro with "Disable" is always necessary?
In fact I dont understand what "Enable exclusive" really does. It is explained briefly in the manual, but unfortunately I dont get it.
Using:
Windows 7 64bit
EventGhost 0.3.7.r1436
Enable exclusive vs Enable? Difference?
Re: Enable exclusive vs Enable? Difference?
I got it:
It only works as expected, when there is another "Enable exclusive"!!! So the automatic disabling doesnt work with just one "Enable exclusive". I rate this a bug.
Programs (folder)
WinMediaPlayer (folder)
Play (macro)
remote.play (event)
Pause (macro)
remote.pause (event)
WinAmp (folder)
Play (macro)
remote.play (event)
Pause (macro)
VLC (folder)
Play (macro)
remote.play (event)
Pause (macro)
To get full usage of 'enable exclusiv', the use of the Task create/switch-plugin is recommended.
Programs (folder)
toggle programs (folder)
enable WinMediaPlayer (macro)
task created 'WinMediaPlayer.exe' (event)
enable exclusive 'Programs/WinMediaPlayer' (action)
enable WinAmp (macro)
task created 'WinAmp.exe' (event)
enable exclusive 'Programs/WinAmp' (action)
enable VLC (macro)
task created 'VLC.exe' (event)
enable exclusive 'Programs/VLC' (action)
