I have been playing with eventghost and have found it to be AWSOME software, but does it have a feature like a "if condition". example, i use rs232 relay controllers and contact closure sensing boards, i can get event ghost to send and receive commands, but is there a way to make a macro that can check conditions.
example.
IF condition b1 is met send command 1a OR if condition b1 is not met dont send command 1a
OR
send command 1a IF condition b1 is met OR send command 1b IF condition b2 is met
command 1a = tv on command
command 1b = no command sent
condition b1 = relay 1 closed
condition b2 = relay 1 open
thanks for any help
does event ghost have this function
Re: does event ghost have this function
Sure, this is really simple to do in a python script. If you have extensive needs, you can also write a plugin for a soft plc
Can u make an example on how release a script waiting for a process to close? Thank you
some simple stuff can also be done be conditional jump and a python command before.
eg.result has to evaluate as True or False
other thing would be script
eg.result = expressionother thing would be script
if expression:
do something
do something else
and an expression for existing process which could be?
if the process has a windows you can simple combine a Find Windows action and do a conditional jump after that.
I need to wait that I close the windows and then the macro can go on... I don't think I can do that with jump... I tryed to use the start application and flag the wait to close but I've yet opened the software at the begin of the script so this command doesn't go...
Elsewhere, can I associate to a macro the closed event and make it go only once a day? It's possibile?
