IrDA on laptop
OlivierMiR
IrDA on laptop
Post by OlivierMiR »
I would like to discover which codes are sent by my remote for my old television. This is to be able to program a new universal remote I just bought.
I thought I might be able to use my laptop's IrDA bult-in port and EventGhost software, use the old remote in front of the port, and somehow see the code sent by the remote appear in the software. Unfortunately I can't find how to do this!
Are you aware of any way to achieve this with EventGhost (or any other software), without buying any hardware?
Many thanks,
Olivier
Post by Bitmonster »
OlivierMiR
FYI
Thank you for the information: I absolutely didn't expect that IrDA and consumer IR was something different!
Searching on the subject sent me to the following explanation which I found helpful: http://www.alanjmcf.me.uk/comms/infrare ... c128227634.
http://www.tuxmobil.org/Infrared-HOWTO/ ... -irda.html has more detailed informations (which I didn't understood).
If someone is aware of a way of receiving TV remote codes with my SMSC IrCC port (which seems to be possible according to http://www.lirc.org/irda.html), without need of a technical background which I don't have, I'm still interrested.
