AND events together, instead of OR ?
Dnq3
Post by Dnq3 »
If you create a macro and add two events, and an action to it, then the action will be performed if either of the events occurs (ie. OR).
Is it possible to only perform an action if both events occur (ie. AND) ?
I want to do this so that buttons have different effects, depending on whether the media player is in a paused state or not. At the moment, I enable/disable certain macros, depending on the state of the player (ie. Paused or not).
Re: AND events together, instead of OR ?
#Python script Aon
eg.globals.var_A = True
#Python script Aoff
eg.globals.var_A = False
#Python script TriggerEvent
try:
    if eg.globals.var_A:
        eg.TriggerEvent("AandB",prefix = "MyEvent")
except:
    pass
This example does exactly what you ask.
If the event "MyEvent.B" occurs after the event "MyEvent.Aon", event "MyEvent.AandB" is triggered .
But if it's after the event "MyEvent.Aoff", nothing happens.
