hey there from germany,
i just want to make the following work:
when i SCROLL the mousewheel (NOT PRESS THAT BUTTON!!), i want to emulate the keystroke "tab".
im gonna use it ingame, so i dont want to have any delay.
my logitech mouseware ("setpoint" isnt capable of that.
hope u can help me, im totally new to this!!
regards
mousewheel scroll -> "TAB"
Re: mousewheel scroll -> "TAB"
The mousewheel isn't captured and games normally work on a level system api you can emulate with special drivers in place.
ok thx, but i still dont know what to do..
i can tell you what i did in the past: i used the program "girder" and someone wrote a macro which enabled me to do as i inititally posted. but i cant use the freeware of that prog under vista. my OP.
aint that really possible qwith this tool??
I don't know if EventGhost can do it, but when I need to remap mouse/keyboard buttons functionality I use freeware Autohotkey.Rabbuni wrote:ok thx, but i still dont know what to do..
Example script to map mousewheeldown -> tab
WheelDown::Send, {tab}jonib
