So, I'm trying to program a button on my remote so I can toggle between monitor and TV, also go into extended mode when desired.
For the toggle part (internal/external), I used the "Enable Exclusive" function, which works perfectly.
For the extended mode, I'm trying to use the "Jump if long press" action. However, it doesn't appear to function. I'm not quite sure if I have it set properly.
I inserted a pic below of my configuration. The blue lines indicate what I have the Jump action set to go to.
I also tried creating a new file, though that didn't work either. Any advice is greatly appreciated, Thanks.
