[Bug?] Task Create/Switch Events Plugin
Kalden
Post by Kalden »
I believe I've found a bug in this plugin. I did a search for a workaround and didn't find any. When you set a window into full-screen mode (using an {Alt+Enter}, the plugin detects that the task was deactivated. This is at least the case for BeyondTV. As well it never detects that the application is once again activated (even though the app as focus).
I have a Task.Deactivated.* macro that enables a generic keyboard mode when I'm not in any certain program that I've configured via EventGhost.
Post by Bitmonster »
I haven't tried BTV, but a possible explanation could be, that BTV is not switching to "fullscreen" as Firefox does for example, but to "always on top". These kind of applications the plugin can't monitor.
Kalden
Post by Kalden »
Well it goes from a windowed mode to a fullscreen mode. However, I was able to find a workaround on my own. By using the Trigger Event Action in my Maximize button's macro, I am able to reactivate BeyondTV a couple of seconds after the button is pressed.
I have to say, this is an EXTREMELY impressive program. Kudos to you and where do I send a donation for your efforts?
You can donate through the projects SourceForge.net page:
http://sourceforge.net/donate/index.php?group_id=145751
