Help with Tellstick Plugin Python Command
woggy
Post by woggy »
I have I server with an Tellstick witch receives this event for an example:
Broadcast.DesktopRemote.Arbetsrum Taklampa '12'
the payload is 12, then I run my Python Command:
eg.plugins.TellStick.Dim(11, eg.event.payload)
The result is bad, maybe 50/50
If I do it like this, and change the number manually it works 100% of the time
num  = 12
eg.plugins.TellStick.Dim(11, num)
Any ideas? Here is the script that sends the event if it has anything to do with it:
num = input("Dimm to: ")
num = num * 255
num = num / 100
eg.globals.num = num
eg.plugins.BroadcastListener.Broadcast(u'{eg.event.string}', u'{eg.globals.num}')
Re: Help with Tellstick Plugin Python Command
Try this:
eg.plugins.TellStick.Dim(11, int(eg.event.payload))
woggy
Post by woggy »
Tnx a lot, it worked :D
woggy
Post by woggy »
I need to abort this script if there is no input for 10 seconds. I have tried a lot of different things but I'm no programmer =)
eg.plugins.Window.SetAlwaysOnTop(0)
def dec():
    while True:
        try:
            num = int(raw_input('enter number between 0 and 100:  '))
            if num > 100:
                print ("Only positive numbers between 0 and 100 please!")
            elif num < 1:
                num = num * 255
                num = num / 100
                return num
        except ValueError:
            print 'Numer only'
dec()
#print "New value is ", eg.globals.num
eg.plugins.Window.SetAlwaysOnTop(1)
woggy wrote:I need to abort this script if there is no input for 10 seconds. I have tried a lot of different things but I'm no programmer =)
After some time I thought of your problem.
You can try this script:
from threading import Timer
from time import sleep
from winsound import PlaySound, SND_ASYNC
class MyTimer():
    def __init__(self, t, dialog):
        self.timer = Timer(t, self.Run)
        self.dialog = dialog
        self.timer.start()
    def Run(self):
        try:
            edit = self.dialog.GetSizer().GetChildren()[2].GetWindow()
            edit.SetValue("Too late !!!")
            edit.SetSelection(-1,-1)
            PlaySound('SystemExclamation', SND_ASYNC)
            sleep(3)
            self.dialog.Show(False)
            self.dialog.MakeModal(False)
            self.dialog.Destroy()
        except:
            pass
    def Cancel(self):
        self.timer.cancel()
class myDialog(wx.Dialog):
    def __init__(self):
        wx.Dialog.__init__(
            self,
            None,
            -1,
            "Self-timeout-aborted dialog",
            style=wx.CAPTION | wx. STAY_ON_TOP
        label = wx.StaticText(self,-1,"Enter number between 1 and 100:")
        edit = wx.TextCtrl(self,-1,"")
        message = "Only positive numbers between 1 and 100 please!"
        w = edit.GetTextExtent(message)
        edit.SetMinSize((10+w[0],-1))
        buttons = self.CreateSeparatedButtonSizer(wx.OK|wx.CANCEL)
        sizer = wx.BoxSizer(wx.VERTICAL)
        sizer.Add(label,0,wx.TOP|wx.LEFT|wx.RIGHT, 15)
        sizer.Add((1,3))
        sizer.Add(edit,0,wx.EXPAND|wx.LEFT|wx.BOTTOM|wx.RIGHT, 15)
        sizer.Add(buttons, 0, wx.EXPAND|wx.ALL, 5)
        self.SetSizer(sizer)
        self.SetAutoLayout(True)
        sizer.Fit(self)
        self.MakeModal(True)
        self.Show(True)
        edit.SetFocus()
        timer=MyTimer(t = 10.0, dialog = self)
        def onButton(evt):
            timer.Cancel()
            if evt.GetId() == wx.ID_OK:
                try:
                    value = int(edit.GetValue())
                    if value >= 1 and value <= 100:
                        value = value * 255
                        value = value / 100
                        eg.plugins.BroadcastListener.Broadcast(u'{eg.event.string}', str(value), 3456)
                        self.Show(False)
                        self.MakeModal(False)
                        self.Destroy()
                        edit.SetValue(message)
                        edit.SetFocus()
                except ValueError:
                    edit.SetFocus()
                self.Show(False)
                self.Destroy()
        self.Bind(wx.EVT_BUTTON, onButton)
wx.CallAfter(myDialog)
You may need to adjust this row:
hanspettersson
Post by hanspettersson »
I borrow this thread a lite.
I got a slider in my webbpage on the webbserver, and whant to control my dimmer whit.
I got this event when i change the slider : "HTTP.lightsSlider.0" the 0 is the value of the slider
Can someone help me with this?
Can i use this Phyton command some way? eg.plugins.TellStick.Dim(10, 50)
And how to get this script run when the value is change?
