Hi all,
Hope you can help me, is it possible to write a script that will do this.
the iphone event ghost has all the buttons i need but can you for example push the tv button and then have the buttons control the tv and then push the film button and then the same buttons then give the signals for say the dvd player making it like a multi remote.
cheers
Edd
remote control question
Re: remote control question
I'm some what of a noob myself, but I figured I would throw this out there...
If you create two folders (/trees) and put all your events for one device under one tree, and all your events for the other under another tree, you can then create an event for the button you want to use as the device switcher, and have it disable one of the trees, while enabling the other one.
That being said, your iPhone doesn't have an IR transmitter, so unless you are relaying your IR from a dongle or an IR blaster, the answer would be no for anything that requires IR (i.e. TV, DVD player, etc).
Hopefully that helps ya
Sounds good. I have a usb uirt so ir is all sorted its just the coding for the change over that i need help with
So if anyone has a plugin for this it would be welcomed
Edd
Edd
