I just got a brand new HP MCE receiver and it's working flawlessly with my XBMC setup without EventGhost so far. But this was only to make sure the basic concept works, now I need to set it up for daily use which means I need to be able to control XBMC when the window is not in focus, due to the same PC being used in a multimonitor setup as a normal workstation and a HTPC.
The issue with EG is that I'm totally unable to get any remote keypresses to register in the events window. I read pretty much every single FAQ and short and long tutorial, but other than disabling the HID service - which does nothing in my case - I've not found what I might be doing wrong - or is my HP MCE receiver which registers as a normal Microsoft eHome tranceiver and as 3 keyboards in the device manager simply not working proplery? But I fail to see how that's possible, since the proof of concept scenario without EG is working.
The remote is a harmony 525, and I've tried to use it both as a microsoft mce keyboard and a microsoft mce 1040 remote, with the same results.
EG version: 0.3.7.r1462
Windows7 x64
And a picture to describe the problem, the events are from detaching/attaching the USB HP MCE receiver. I tried pressing pretty much every button on the remote afterwards without any event being picked up.
All help is kindly appreciated.
