Macro stops part way through
ijourneaux
Post by ijourneaux »
I have a macro that locatesa specified window and kills it off and then opens another application. Unfortuantely if the window doesn't exist, the macro stops at the point it trys to kill the missing window. THis could be by desing but if it is, how do I code the macro to contine on to start the new ppplication if the first window odesn't exist.
Take Care
kalia
Re: Macro stops part way through
Post by kalia »
In the Find a Window macro dialog box, remove the check mark from the option "Stop macro if target is not found".
ijourneaux
Sorry for asking an obvious question. Appreciate th help though.
