MPC-Home Fullscreen window state status?
molitar
Post by molitar »
Currently for my windows state I am using the script below.
from win32gui import GetWindowPlacement
#SW_SHOWNORMAL = 1
#SW_SHOWMINIMIZED = 2
#SW_SHOWMAXIMIZED = 3
FindWin = eg.WindowMatcher(None, None, u'MediaPlayerClassicW' , None, None, None, True, 0.0, 0)
hwnd = FindWin()
def GetWindowStatus(hwnd):
    showList  = (None, "Normal", "Minimized", "Maximized")
    placement = GetWindowPlacement(hwnd)
    #unrem the below line to display the placement values that you need for the if placement[4] line
    print placement
    if placement[4] == (-1920, 1048, 0, 2128):
        return "Fullscreen"
        return showList[placement[1]]
eg.globals.WindowsState = GetWindowStatus(hwnd[0])
print "Windows State = " + eg.globals.WindowsState
Works good but if I make any change in screen settings than I need to change the placement values. Now I am using show fullscreen on another display so is it possible to modify script to see if the display is showing on display 1 or display 2? Or any other method how I can check the window state for fullscreen? I am using this to determine where to show the OSD for volume controls or menus to display on.
