hey guys,
I've been using evenghost for a while now but this has been bugging me. every time i restart my computer or eventghost, i have to load my configuration file manually. by default it loads up an "example" file. how do i make it so that it loads my configuration file automatically every time it starts up??
many thanks!
how to load a config file on startup?
Re: how to load a config file on startup?
EventGhost normally loads the last config loaded.
(Documents and settings)\(Username)\Application Data\EventGhost\config.py this is where (on my system) EventGhost saves what config file to load on start and other settings, maybe EventGhost can't save this file properly on your system.
You could specify the config you want EventGhost to load with the -file <filename> command parameter by changing the shortcut that you use to start EventGhost.
