I have a short macro in EventGhost that is supposed to find the XBMC window then close it.
Unfortunately the close statement only minimizes XBMC. A similar macro to find and close BeyondTV works as expected.
Is this a bug or expected behavior? If expected behavior how to I make sure the application is closed out and not just minimized.
Take Care
Macro to close XBMC only minimizes it
ijourneaux
Re: Macro to close XBMC only minimizes it
You don't show what macro you use so I don't know why it don't work.
You should try the Quit macro from the XBMC plugin or if you use my XBMCRepeat plugin use the XBMCRepeat\Actions\Shutdown related\Quit XBMC. those work for me, and you don't need to find the XBMC window first.
