I created a simple macro to close xbmc.exe using the close command. When it executes, rather than closing xbmc, xbmc gets minimized to the taskbar. At that point, it is in a hosed state and I have to kill it with task manager.
Shouldn't this work? Is there another way to accomplish the same thing?
EventGhost Macro to close XBMC
ijourneaux
ijourneaux
Re: EventGhost Macro to close XBMC
Sorry about that. Forgot that I had already asked the question.
I did find a solution. Installing a new version of XBMC seems to have resolved my issue and close now closes the application. This was such a simple macro is was hard to understand why it wasn't working.
No off to try and get my X10 Usb adapator to work.
Take Care.
Take Care.
