X10 plugin dimming
ubergeek7
X10 plugin dimming
Post by ubergeek7 »
I know that I should put this in the plugin forum. But I cannot create a new post there.
I dont know if it is possible to dim lights using the x10 plugin. If so, I cant find anything except for an old plugin that runs commands from the command line.
if anyone could help me, I would greatly appreciate it.
zian
Re: X10 plugin dimming
Post by zian »
I use EG to trigger batch files that use sct.exe to allow control of x10 moduals (on,off,dim,bright) through my old serial port Firecracker.
eventghost.net
Be there or be square.
