Minimizing to system tray
When you enable the option "minimize to system tray on close" it should work like minimizing so the memory consumption should be as when minimized, notice that if you minimize, the memory consumption goes really down but if you close with the option enabled (it minimizes) but the memory consumption stays the same.So it's actually not "minimize to system tray on close" but "close to tray"...
