I have the standard HP IR Receiver/Blaster with one blaster cable hooked up to input #2 on the back. I also have a Panasonic plasma tv.
I'm trying to be able to use the MCE remote that came with my HP computer to blast the volume +/- and TV Power Toggle to the tv so that I can avoid buying a Harmony remote. (I already have a few and don't need another for these three actions on this TV.)
In EG the functions I want to transmit to the tv via the blaster (captured from the Panasonic remote) are recognized in the log as mceremote.8485, mceremote.405, and mceremote.bcbd.
What I am wondering is, is there any way to have it just retransmit these MCE commands, or do I need to go find the discrete ccf codes, or try and get the IR capture to work? Seems like if they are already showing up as MCE codes, that the work is done.
Have not been able to get it to work, which is why I am asking here.
Thanks.
Transmit Panasonic Remote Codes via HP IR Blaster
Re: Transmit Panasonic Remote Codes via HP IR Blaster
I would assume you need to send out the so called pronto codes via the IR-blaster (if it supports it). Like the USB-UIRT does it
To find pronto codes for your tv, maybe they have them at remote central
ftp://ftp.panasonic.com/pub/Panasonic/D ... format.pdf
Hello!krambriw wrote:I would assume you need to send out the so called pronto codes via the IR-blaster (if it supports it). Like the USB-UIRT does it
The same almost a problem. Projector Panasonic PT-VW535N.
In the log, after pressing the power button, two entries are displayed, not one.
It is not possible to write code from the remote control to the MCE console.
Code or generated or duplicated?
