Support for multiple independent MCE receivers?
eventghostPete
Post by eventghostPete »
If I attach multiple MCE Remote Receivers (one in each room, to control it's own monitor, coming off the one multi-videocard server), can I, within EventGhost, distinguish between event comings from a particular remote?
I want each remote's events to be routed to a pre-assigned instance of a program (which is shown on its own unique monitor).
And likewise, can I send IR codes to each blaster independently? (Each room has it's own audio amplifier with a {serverUSB->USBsoundcard->optical/coaxSPDIF} input
stottle
Re: Support for multiple independent MCE receivers?
Post by stottle »
This might be possible (I think I saw something about multiple instances of the plugin, I'm not positive) using the USB-UIRT. It isn't possible with the MCE plugins.
Brett
