In the 'Find Window' Action you can set it to stop if the window is not found... but I'd like to stop the process if it IS found. Is this a missing feature?
Must I add a do nothing macro and jump to it?
My goal...
I want to check to see what apps are running before I decide if I should turn off my receiver.
Check J River Media Center
- if on, stop macro
- if off, continue
Check XBMC
- if on, stop macro
- if off, continue
Turn off Receiver
Stop Processing Macro IF Window Found - missing?
Re: Stop Processing Macro IF Window Found - missing?
Maybe you could use a jump action (to jump to an empty macro):
- <FindWindow> "Media Center" ('stop macro if target not found' unchecked)
<Jump> 'if last action was successful' to macro "StopMediaCenter"
... (actions if window not found)
I'm using Jumps but this is not efficient IMO and just extra work for no benefit. We really need to have an additional option in the Find Window action.
