Export settings issues
I have exported my xml file and tried to set up the same system on an embedded machine. When I load the files the settings come up and look somewhat normal. except that all of my cm15a commands show up as though they are not registered and will not register any commands issued via the normal commands from the original setup. do I have to reattache the commands to the program again? I hope not, I have been doing this for months, most of the things on there are IR codes and cm15a x1 commands.
