hello all,
I would like to map a key to my mce remote that logs off the current xbmc user (and takes me to the login/profile screen)
Any ideas how to do this? thanks!
macro to logoff xbmc user
Re: macro to logoff xbmc user
My plugin XBMCRepeat has that action "XBMCRepeat\Windows\Loginscreen", it appears to logout and show the login screen.topsyturvy wrote:I would like to map a key to my mce remote that logs off the current xbmc user (and takes me to the login/profile screen)
topsyturvy
sorry if I wasen't clear.
I would like to stay within xbmc but switch xbmc users. So i need to go to the xbmc user selection scene and not the windows!
Hmm, you want a button on your remote to go to the login screen within XBMC? like the below image.topsyturvy wrote:sorry if I wasen't clear.
Well that's exactly what my suggestion does, if that's not it then I can't help.
topsyturvy
ah, I didn't realise that. Then thats exactally what I need!
I'm using the standard xbmc plugin, guess I'll have to move over to xbmc repeat.
Thanks.
Thanks.
