Most of the time I have EventGhost working fine and it will load my custom XML file, normally even after a reboot of the computer. However, sometimes it seems to revert back to example.xml. This usually seems to be after the computer has restarted following a crash (like a blue screen error) or if it has been restarted by Windows Update to install updates.
Is there a setting in EventGhost which controls the default XML file to load which I am not setting?
EventGhost sometimes reverts back to example.xml
- InterlinkKnight
Re: EventGhost sometimes reverts back to example.xml
That's strange. Maybe if you rename your custom XML file to "example.xml", and remove the original "example" file.
