I'm new here, so I'm sorry if this is a stupid question.
I am looking to buy myself a USB remote so that I can run xbmc on my Windows 7 machine and control it from my bed (PC is on the other side of the room) - this is probably going to sound lazy (it is...), but what I ideally want is to be able to have a button on the remote that will turn the PC monitor off as well as turn the Logitech Z-10 speakers off, while leaving the PC on (not standby or hibernate).
Now I have had a look and I have seen/tested that EventGhost can turn the screen off without any problem, it can also mute the speakers - however, these Z10's have a very bright LCD screen on them, and although muting them is helpful, I really want to be able to power them down completely otherwise the room's too bright to sleep
My layman's view is that as they are USB interfaced and have no physical power switch (it's all touch-sensitive controls), this should be possible, but I haven't got a clue if it actually is or not.
I'm not asking anyone *how* to do this, just whether this is the type of thing EventGhost is able to do if configured correctly?
Thanks a lot in advance.
Sagramore
