Force app to open, or move, to 2nd display?
Livin
Post by Livin »
I'd like to have specific apps open directly on my 2nd display... or, when it detects the display becomes active, move the app to it.
Anyone have python code to do this? It would make for a nice plugin ;)
closest thing I found has been...
# Copyright 2010, Trent Nelson ([email protected]).
# $Id: fix-window-placements.py 6 2010-08-10 09:58:58Z Trent $
from win32gui import (
SetFocus,
MoveWindow,
EnumWindows,
GetClassName,
GetWindowRect,
GetWindowText,
IsWindowEnabled,
IsWindowVisible,
GetDesktopWindow,
GetWindowPlacement,
from ctypes import (
windll,
c-int,
c-long,
c-ulong,
c-double,
POINTER,
Structure,
WINFUNCTYPE,
class RECT(Structure):
-fields- = [
('left', c-long),
('top', c-long),
('right', c-long),
('bottom', c-long)
def dump(self):
return map(int, (self.left, self.top, self.right, self.bottom))
MonitorEnumProc = WINFUNCTYPE(c-int, c-ulong, c-ulong, POINTER(RECT),
c-double)
def enum-display-monitors():
results = []
def -callback(monitor, dc, rect, data):
results.append(rect.contents.dump())
return 1
callback = MonitorEnumProc(-callback)
temp = windll.user32.EnumDisplayMonitors(0, 0, callback, 0)
return results
def get-desktop-area():
left = top = right = bottom = 0
for r in enum-display-monitors():
if r[0] < left:
left = r[0]
if r[1] < top:
top = r[0]
if r[2] right = r[2]
if r[3] bottom = r[3]
return (left, top, right, bottom)
def inside-desktop(hwnd):
desktop = get-desktop-area()
rect = GetWindowPlacement(hwnd)[4]
return (
rect[0] rect[1] rect[2]
Re: Force app to open, or move, to 2nd display?
Once I answered a similar theme, but the author of the original request did not bother to respond somehow.
I think it's strange, even if my solution is not good.
Livin
Post by Livin »
no disrespect meant... I honestly did not even see it. I've been crazy traveling for work, and taking care of my 1 yr old when I'm home - forgot I even posted that!
I will check it out now and let you know how it works for me... many thanks!
