Undo Enable Exclusive
matejdro
Post by matejdro »
I have several separate folders for several programs. And i have folder "Multitap" which is for text entry. Idea is that when i press "T" button on my remote, it will switch from whatever application is enabled to Multitap. And when i finish typing it would switch back to where it was before i enabled Multitap.
I have managed to switch to Multitap with Enable Exclusive Folder function, but i don't know how to switch back. Is there a way to somehow make a variable?
jinxdone
Re: Undo Enable Exclusive
Post by jinxdone »
Put your multitap macros outside the folder in which you are using the "enable exclusive" action, so your config tree would look something like..
+ Multitap
+ Volume control
+ Context specific
   + Winamp
   + VLC
   + XBMC
This works because the "enable exclusive" will enable/disable between items on the same level as the target. So in the example using it to switch between Winamp <-> VLC <-> XBMC wont affect the state of the Multitap or Volume control folders, which are one level up in the config tree.
