Using EventGhost to trigger auto hotkey macro?
Does anyone know how to create a macro that will trigger a macro in auto hotkey?
Re: Using EventGhost to trigger auto hotkey macro?
Not sure if you found your answer but I was trying to do the same thing tonight and I couldn't figure out how to run soooo I compiled it into an exe file. To do so, go into your AutoHotKey folder, then open Compiler and use the Ahk2exe app. Once in there, select your source script and then from the File menu, choose Convert.
You will then have an exe file which you can run
Hope it can help.
Hope it can help.
