Need help with Network sender
Sonopanic
Post by Sonopanic »
i start the plugin Network Event Sender.
The only command i have is "map".
No documentation, nothing. How can i use it ?
I need send a string over IP to a global cache box.
192.168.11.36 Port 4999
Data : 3,1,3,1 (no cr)
kingtd
Re: Need help with Network sender
Post by kingtd »
Check out my response to this same question, but on the thread for my network broadcaster. Basically the network sender uses the old "Girder" handshake, so you can't just send arbitrary data on the network directly with it. But you can write a quick python script to do it:
http://www.eventghost.org/forum/viewtop ... 272#p12272
~K
Sonopanic
Post by Sonopanic »
Thank you, but my testscipt do not work.
python script :
import socket
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.connect(("192.168.11.36", 4999)) # Specify the target device and port number
print s.recv(1024) # Writes anything it tells you when it first connects to the log for troubleshooting. If there's no initial connect string, you can probably remove this line
s.send("1,1,0,0\n")
s.send("3,1,1,3\n") # You could also do eg.event.payload[0] and pass commands to this script from other events.
print s.recv(1024) # Writes anything it tells you after your command is sent to the log for troubleshooting
s.close()
In the log appear a python script, but after that, eg hung up.
No command are send to the globalcache.
The data, i want to send are four bytes. Is the string with the commas correct ?
jinxdone
Post by jinxdone »
You should write it as "\x03\x01\x03\x01" if you want to send literal bytes. Check python docs about string literals for reference http://docs.python.org/reference/lexica ... g-literals
Sonopanic
Post by Sonopanic »
it works !
import socket
HOST = '192.168.11.36'
PORT = 4999
s.connect((HOST, PORT)) # the Host in " " works too.
s.send('\x08\x01\x01\x08') # in my case, no LF or CR needed
s.close()
