Problem with an HID remote
rsacchi
Post by rsacchi »
I've bought this remote:
It works good both as keyboard than mouse with PC, but I don't know how to make it works on EventGhost.
In control panel it's recognized as USB remote, HID compatible.
In EventGhost I add a plugin as GENERIC HID, then I choose the USB remote "PING-IT" manufacter (there're two istances) but when I try to press some buttons, it still works as keyb with PC but the signals don't appear in log panel.
Any help?
Rob
rsacchi
Re: Problem with an HID remote
Post by rsacchi »
I need help, please :P
specter333
Post by specter333 »
Only thing I can think of here is the "Log only assigned and activated events" check box in the lower left corner. You did un-check that didn't you?
