Web gui for web server
sebnil
Post by sebnil »
I was searching for a web gui for Eventghost but could not find anything decent. I made my own and perhaps others will find it useful:
http://sebastiannilsson.com/open-source ... st-web-gui
Modify the html to suit your needs. It uses an ajax function for sending events and you specify your events in the title attribute for every div.
It is built with jQuery Mobile so it should work fine on most mobile devices including Iphone and Ipad. I tested it on an android phone and it worked quite good.
__________________
treplex.se
Livin
Re: Web gui for web server
Post by Livin »
looks really nice!
Can you build in a function to auto create buttons based on Macros that exist?
... the function would look at each macro in EG and create a button for it if specific conditions exist.
... those conditions could be something like the way the way the event is named, maybe having a "-web" on the end, or a comment object in the macro, etc.
do you think it is doable?
sebnil
Post by sebnil »
Livin wrote:looks really nice!
It is doable but not something I will invest time in right now. I chosed this solution because it is easy to style and build more complicated interfaces with html. I think this is difficult to automate, but it is doable.
__________________
treplex.se
sebnil
Post by sebnil »
I have added some support for sliders and two examples for volumebar and lightcontrol. It uses the dynamic webserver to update variables. Take a look at:
http://sebastiannilsson.com/open-source ... -and-light
It allows you to set volume and light dimmers directly.
__________________
treplex.se
Hi Sebastian,
I would wish it worked also with a normal browser from Windows. I see a nice way to modernise my existing layout.
With IE, only the text is shown, with Firefox it looks ok but only the sliders generate events in EG
Any hint if it is supposed to work an I'm doing something wrong?
sebnil
Post by sebnil »
krambriw wrote:Hi Sebastian,
jQuery Mobile does not work in IE. I have tested it in firefox, chrome and android browser. Every button should generate an event and I do not know why it doesn't work for you. Test it in the latest version of Chrome or Safari.
__________________
treplex.se
OK, thanks, Chrome works fine, I think there are some issues with firefox but nevermind
m19brandon
Post by m19brandon »
This is great, thanks for all the hard work.
