I am attempting to create a macro that plays a sound file (or does other event) repeatedly after an elapsed time (say 30 seconds). The macro and the sound event should not get in the way of other macros and events.
With the auto-repeat action, I can get the macro to repeat after a certain time, but all other event triggers/macros are ignored while it is running. The sound file (or other action) are short (less than half a second), so it shouldn't get in the way of the rest of the events/macros.
How would I set this up?
Trigger repeating macro after elapsed time
Re: Trigger repeating macro after elapsed time
Use the triggerevent action with timer.
