Hello friends,
I am using the last release of EvenGhost together with the Conceptronic remote control. Also using the corresponding USB driver for said remote. The system I use is Windows 7 x64.
In the beginning and for several hours or so, everything works fantastic. But after that, and many times, I found no response at all to the control remote. Then I have to either close the EG application and start it again or, even, restart the whole PC in order for it to work again.
Please tell me if there any solution to this problem, in case it is happening to anyone else.
Thanks in advance,
Mabruk
