timer funktion doesn`t work.
bolets
Post by bolets »
How do i get the timer funktion to work. I cant find out how...
i want to start an application at. 08.00 and run just once.
vuego
Post by vuego »
First add a plugin Timer.
Then add an action Timer/Start new or control running timer.
The default setting is run just once. Change Start to at given time (HH:MM:SS).
Then trigger this action in the way you prefer.
bolets
Post by bolets »
great! working fine. But if i want to execute a task every day at 08:00 or if i want to execute every sunday. How is this done?
vuego
Post by vuego »
To make it execute every day set:
Loops = 0
Interval = 86400
Start = at given time (HH:MM:SS)
I don't know about every Sunday. You might have to script it.
bolets
Post by bolets »
thats how i set it up now. But it should be great if i could execute the macro only on sundays.
