when i press f1 key monday-saturday i want it to insert 12345 insert a key sequence. When i press f1 key on sunday i want it to paste 6789. Can this be done with this fantastic program? How then?
remap keyboardkey diffrent for different days.
Insert a Python script with the following code in your macro immediately followed by a jump action.
import time
eg.result = time.localtime()[6] == 6This should to the trick. Just copy and paste the code below.
<EventGhost Version="939">
<Folder Name="Test" Expanded="True">
<Macro Name="Python Skript" Expanded="True">
EventGhost.PythonScript(u'import time\neg.result = time.localtime()[6] == 6')
EventGhost.NewJumpIf(XmlIdLink(536), 0, False)
<Action Name="WeekdayAction">
EventGhost.Comment()
<Macro Name="SundayMacro" id="536" Expanded="True">
<Action Name="SundayAction">
</EventGhost>sorry but i really dont get this. I have created a python script with the encloesed code. i have also made a macro called WeekdayAction and a macro called SundayAction. But i cant get it to work. Do i use jump to after the script or what should i do?
Discriptions log:
AttributeError: Compile instance has no attribute 'code'
Discriptions log:
