Hi
I cannot launch Eventghost by "EventGhost start when windows does" selection.
Th shortcut into "start" folde works fine.
I use EventGhost with Win7
Everyone know an issue ?
Regards
Option "EventGhost start when windows does" dos'nt work
Re: Option "EventGhost start when windows does" dos'nt work
Mine starts just fine on my computer (also using Windows 7), but I noticed that when I restart my computer even though EventGhost is running it doesn't see the remote signal, so I have to close it and then launch it again.
So what I did was just disable the autostart and I start it manually when I reboot my PC which is ok since I only reboot once every couple of weeks.
