Problem with sending keys
piet5211
Post by piet5211 »
I am trying to create a plugin for slingplayer which sends keystrokes to slingplayer. For example Alt+p plays/pauses a stream. However only the first time I press the right button on my remote the alt+p is sent to slingplayer, after that, every time I press the same button on my remote, only p is sent. What is happening here?
Windows 7 professional
Eventghost 0.3.7.r1462
haagar
Re: Problem with sending keys
Post by haagar »
I am having a similar issue under Windows 7 Home Premium x64 with EventGhost 0.3.7.r1486.
I am using keys that send a + or - command through the HID plugin for maximize/restore with slingplayer. However it only works the first time and then it sends the + or -.
