Help to dim a tellstick device
baskarl
Post by baskarl »
Hello everyone, I have problem to dim my lights. The tellstick device works fine to turn the lights on and off but when I try to dim it doesn't work. If I try to dim my lights directly with telldus software Telldus Center i works fine.
Please someone help me!
logfile:
23:38:47 Unhandled exception in WorkerThread <ActionThread>:
23:38:47 Callers stack:
23:38:47 File "wx\_core.pyc", line 8007, in MainLoop
23:38:47 File "wx\_core.pyc", line 7303, in MainLoop
23:38:47 File "C:\EventGhost\eg\Classes\MainFrame\TreeCtrl.py", line 375, in OnContextMenu
23:38:47 File "wx\_core.pyc", line 10249, in PopupMenu
23:38:47 File "C:\EventGhost\eg\Classes\MainFrame\__init__.py", line 344, in FuncWrapper
23:38:47 File "C:\EventGhost\eg\Classes\MainFrame\__init__.py", line 875, in OnCmdExecute
23:38:47 File "C:\EventGhost\eg\Classes\Document.py", line 412, in ExecuteSelected
23:38:47 Traceback (most recent call last) (1462):
23:38:47 File "C:\EventGhost\eg\Classes\ThreadWorker.py", line 201, in __DoOneEvent
23:38:47 File "C:\EventGhost\eg\Classes\ActionThread.py", line 78, in HandleAction
23:38:47 File "C:\EventGhost\eg\Classes\ThreadWorker.py", line 72, in __call__
23:38:47 File "C:\EventGhost\eg\Classes\ActionThread.py", line 58, in ExecuteTreeItem
23:38:47 File "C:\EventGhost\eg\Classes\ActionItem.py", line 227, in Execute
23:38:47 File "C:\EventGhost\eg\Classes\TreeItem.py", line 448, in Print
23:38:47 File "C:\EventGhost\eg\Classes\Log.py", line 152, in Print
23:38:47 File "C:\EventGhost\eg\Classes\Log.py", line 147, in _Print
23:38:47 UnicodeDecodeError: 'ascii' codec can't decode byte 0xf6 in position 16: ordinal not in range(128)
/Karl
Re: Help to dim a tellstick device
Have you used ├Ñ,├ñ or ├ in the name of the device?
Which plugin are you using? The one built in or this
viewtopic.php?f=9&t=2081
baskarl
Post by baskarl »
It is now working, strange! I don't realy have full understanding but working on it :D
