Android: Wake on Lan with every button, even with a call...
Buddhakeks
Post by Buddhakeks »
my Problem is that every buttons makes my pc turn on. That would not be that bad. But when i make a call my pc turns on... Even when i dont have a "Wake on Lan" macro at Eventghost.
How can i fix that?
Buddhakeks
Re: Android: Wake on Lan with every button, even with a call
am i the only one who uses an android phone?
And btw, the problem is gone when i deinstall eventghost for android.
Buddhakeks
ok it was something wrong with the network card...
zian
Post by zian »
Buddhakeks wrote:ok it was something wrong with the network card...
Thanks for letting us all know Budd.
Glad you got it figured out.
eventghost.net
Be there or be square.
liquid8
Post by liquid8 »
Sorry I didn't get to this, but there is an Android Events plugin (which is now included default in the app), this allows the app to send Android events to EG - including incoming/outgoing phone calls, incoming sms, and battery status.. if anyone else has this issue, make sure you configure the plugin, or disable it if you don't want this option :)
