Global Cache iTach
KeKs0r
Global Cache iTach
Post by KeKs0r »
i am a proudly owner of an global cache ip2ir iTach , which works pretty nice with my commandfusion, but I am struggling connecting it with eventghost (start amp and tv when starting htpc).
I am not the hard core technical guy, so I dont understand the exact detail, how the communication between pcs and the iTach device work. I just have used their iLearn to get the code for my command:
[POWERTV] sendir,1:1,1,37993,1,1,171,171,21,64,21,64,21,64,21,21,21,21,21,21,21,21,21,21,21,64,21,64,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,3799
I just tried to send exact this string with the network event sender to my iTach on Port 4998. Nothing happened.
Then i tried the python script in this thread: didnt work either.
Has anyone an Idea or plugin to use my iTach?
Marc
Re: Global Cache iTach
For help, pls publish here exactly the script you tried . There is a well documented api for this device
BestR Walter
BTW the string above should not end with a comma
