Insensitive remote
zkab
Insensitive remote
Post by zkab »
I have Steamzap remote and it works OK from a functional way with EventGhost ... but I have discovered that sometimes when I press buttons on the remote it doesn't react ... but my wireless keyboard reacts immediately. The distance is 2 meters from remote to receiver and clear vision.
An example ... I press OK button on the remote (which generate {return} in EventGhost) and there is no reaction, when I press 'return' on the keyboard the reaction is there at once.
When checking the EventGhost log it tells me the Streamzap.OK was pressed.
When this strange behavoir occurs I can see that red light at the receiver flashed like an exploding supernova for 10-15 seconds.
Is there away to debug what is going on ... now I only can check the EventGhost log.
I can provide the configuration file for EventGhost ... if I only knew where to find it (running Windows XP).
