hold key - do sth - release key
temporaryaccount
Post by temporaryaccount »
Hi everyone!
I'm having problems trying to compose a macro: I would like to press the CTRL-key and hold it, then scroll the mouse wheel up/down and then release the CTRL-key in order to zoom in various windows (no, it's not possible to use CTRL+ and CTRLÔÇô instead).
Yes, I've searched for solutions in this forum and with google, but couldn't find any.
Is it possible to solve this with EventGhost itself or do i have to learn Python and write a script?
Thx for any help!
Chris
zian
Re: hold key - do sth - release key
Post by zian »
Howdy Chris,
You might try a search for Ctr-Alt-Tab here at EG.net.
I think the macro/script you find will be editable (in python? Change a few keys?)
I use that one and it presses and holds the Ctr key while tapping the Alt key to scroll through open windows.
If you can change a few of the keys, or use only the press/release Ctr key script and stick a mouse wheel movement in there it might work.
eventghost.net
Be there or be square.
