Wake Up my HTPC with USB-UIRT/Eventghost/W7/MSI board
THX-UltraII
Post by THX-UltraII »
Hi guys,
I have I question:
I would like to be able to turn on my HTPC with my Logitech Harmony Remote. Can someone tell me how to config this to work properly? I did see a 'Wake On LAN' macro in Eventghost but I assume this is only meant for waking up another PC?
Here s my setup:
- MSI G41M-P28 mainboard (with latest 7592vQ6 bios)
- USB-UIRT
- Eventghost 0.4.1.r1512
- Logitech Harmony Remote 900
Can someone tell me step-by-step how to config everything in order to make it work?
altainta
Re: Wake Up my HTPC with USB-UIRT/Eventghost/W7/MSI board
Post by altainta »
Okay what u need is pc on off system
Well what u can do is buy this thing
http://www.simerec.com/PCS-2.html it is better than getting ur hands dirty...
Well turning pc on and off is all hardware based so i guess event ghost can't help in this scenario...
I my self done DIY remote as cheap as possible.. But i can't share because it is harm full process.
better stick with above solution simerec which will be enough for ur need.. You can program any key of your remote to it...
Hope you find ur answer
USB-UIRT can't help in the scenario either...
