On Screen Keyboard with Dictionary Support
altainta
Post by altainta »
On Screen KeyBoard with dictionary support.
It will be easy to type some few things
Check out the XBMC On Screen Keyboard. It also have a capslock and i use it. Best by far. http://wiki.xbmc.org/index.php?title=On_Screen_Keyboard
Only few buttons are needed
up, down, right, left, ok(enter), esc(close) that is it..
I tried the xp key board but it doesn't work with the above buttons. Need point and click.
Re: On Screen Keyboard with Dictionary Support
It's an interesting idea. But I can not promise anything. Can anyone do it. There are more people who could prove it.
I'm just thinking that maybe sometimes I will create it. Meanwhile you have to use the plugin Multitap.
Please explain what it means "with Dictionary Support".
altainta
Post by altainta »
Windows 7 on screen key board have a Dictionary function here it is (got it from net)
Just like Google "AUTO SUGGEST". While typing it Suggest Words.
Some alternative words to define this function Auto Suggest, word prediction, Dictionary, Suggestion...
Windows 7 on-screen keyboard with predictive text
Oh, this is the feature that I absolutely hate :D .
altainta
Post by altainta »
i don't know why said hate...lol i guess miss typed (Like or hate)
No hurry You can do whenever you want..
hadnafeesn
Post by hadnafeesn »
Well im still finding where i can download this one
grea
Post by grea »
Help to to download this
rdokoye
Post by rdokoye »
I donÔÇÖt think IÔÇÖm familiar with any native dictionary support, although I use WordWeb, which is fairly integrated into my OS, it offers a range of features which are similar to GoogleÔÇÖs Suggestion Tool.
"The first rule of any technology used in a business is that automation applied to an efficient operation will magnify the efficiency." - Bill Gates
