auto reload config file on resume
shready
Post by shready »
Hi I'm using EventGhost 0.4.1.r1522 on windows xp home with a UIRMan serial. When the pc resumes from hibernate UIRMan does not initialize and will not work.
I find if I reload my config it fixes the issue. I would like to have this happen when the resume event happens.
any help would be Greatly appreciated.
Or is there a fix for this problem. It works OK in EventGhost 0.3.7.r1462 99% of the time
Livin
Re: auto reload config file on resume
Post by Livin »
Have Eg detect the resume and start a bat file that restarts EG
shready
Post by shready »
Thank You
That is what I do now I was hoping for a better solution.
Maybe help this:
shready
Post by shready »
Thank You very much .
That will work very well for me
