Stop App / Start another App after event
GBWebmaster
Post by GBWebmaster »
Hello Community,
I have opened a topic in the German forum, but nobody could help me.
The following szenario:
When I mount a dvd or a iso-image (Event: "System.DriveMounted.H"), EG should check, if a application like dvbviewer runs this time. And, if so, EG should close dvbviewer and start PowerDVD. After remove of the dvd or the iso-image, EG should close PowerDVD and start dvbviewer. If no app runs, EG should only start PowerDVD.
Is this possible?
Thanks for all advices.
GBWebmaster
F├╝r den, der nie das Rudel anf├╝hrt,
jinxdone
Re: Stop App / Start another App after event
Post by jinxdone »
Maybe something like this will do the trick? (copy&paste into EG)
<EventGhost Version="1397">
    <Folder Name="Disk Insert/Remove" Expanded="True">
        <Macro Name="Disk inserted">
            <Event Name="System.DriveMounted.H" />
                Window.FindWindow(u'dvbviewer.exe', None, None, None, None, None, False, 0.0, 2)
                EventGhost.NewJumpIf(XmlIdLink(825), 0, True)
                System.Execute(u'C:\\Program Files (x86)\\PowerDVD\\powerdvd.exe', u'', 0, False, 2, u'')
        <Macro Name="Disk Removed">
            <Event Name="System.DriveRemoved.H" />
                Window.FindWindow(u'powerdvd.exe', None, None, None, None, None, False, 0.0, 2)
                EventGhost.NewJumpIf(XmlIdLink(838), 0, True)
                System.Execute(u'C:\\Program Files (x86)\\DVBViewer\\dvbviewer.exe', u'', 0, False, 2, u'')
        <Macro Name="DVBViewer: Exit" id="825">
                Window.FindWindow(u'dvbviewer.exe', None, None, None, None, None, False, 0.0, 0)
                Window.Close()
        <Macro Name="PowerDVD: Exit" id="838">
                Window.FindWindow(u'powerdvd.exe', None, None, None, None, None, False, 0.0, 0)
                Window.Close()
Change all the paths of the programs to correspond with your setup. I didn't test if it works or not.. :) If it doesnt work right out of the box tinker about with the macros, you should be able to see the idea how it can be done.
GBWebmaster
Great, it works.
Thank you very much.
GBWebmaster
GBWebmaster
One more question, sorry.
Is there a chance to start the movie playback in PowerDVD automatically. At the present time I must press the "Play-Button" to start the movie in PowerDVD.
GBWebmaster
Maybe this is the way:
Python script:
from time import sleep
findPowerDVD = eg.WindowMatcher('PowerDVD{*}.exe', 'CyberLink PowerDVD{*}')
hwnds = []
while not hwnds:
    hwnds = findPowerDVD()
    sleep(0.1)
I didn't test if it works or not ...
I realized the need to do some insurance in case that PowerDVD will not start:
Python script:
hwnds = []
i = 0
while not hwnds:
    sleep(0.1)
    i += 1
    if i == 200:
        break
if i < 200:
    eg.SendKeys(hwnds[0], '{Return}')
    print "Cyberlink PowerDVD not found"
GBWebmaster
Hello Pako,
after insert the scriptcode, I get the following errors:
15:09:25   Error compiling script.
15:09:25   Traceback (most recent call last):
15:09:25   IndentationError: unexpected indent (1, line 1)
Is it a problem, that I work with the PowerDVDCinema10.exe under "C:\Program Files (x86)\CyberLink\PowerDVD10\PowerDVD Cinema\PowerDVDCinema10.exe"?
GBWebmaster
No, check line 1 of your script and you will see that you have a improper indentation of your code.
GBWebmaster
Sorry, my mistake. Copy & Paste was no good idea ... ;)
Now it works.
I have a favor to ask you. Could you tell me, what the script does?
GBWebmaster wrote:I have a favor to ask you. Could you tell me, what the script does?
Of course I can.
The script tries (every 100ms), if it can find a window of PowerDVD.
Once the window is found, the script sends (to the found window) the command Play and ends.
If the window is not found within 20 seconds, the script ends.
GBWebmaster
Thank you, Pako.
I have a bit of a problem with PowerDVDCinema. With your script, every movie resume playback from the last scene.
What must be changed to play movies always from the beginning? Is this possible?
GBWebmaster
I do not know.
I do not use PowerDVD.
Perhaps this modification could help:
hwnds = []
i = 0
while not hwnds:
    sleep(0.1)
    i += 1
    if i == 200:
        break
if i < 200:
    eg.SendKeys(hwnds[0], 's')
    sleep(0.1)
Note: 's' is PowerDVD command Stop.
It may also be that your PowerDVD program uses a different keypresses to control.
GBWebmaster
Hello Pako,
the additional scriptcode doesn't change anything.
But when I add the action "CyberLink PowerDVD: Navigation Down" and "CyberLink PowerDVD: Play" after your script, then it works.
Could I add the step "Navigation Down" into the script?
<EventGhost Version="1534">
    <Macro Name="Laden einer ISO-Datei" Expanded="True">
            EventGhost.NewJumpIf(XmlIdLink(1418), 0, True)
            System.Execute(u'C:\\Program Files (x86)\\CyberLink\\PowerDVD10\\PowerDVD Cinema\\PowerDVDCinema10.exe', u'', 0, False, 2, u'')
            EventGhost.PythonScript(u'from time import sleep\nfindPowerDVD = eg.WindowMatcher(\'PowerDVD{*}.exe\', \'CyberLink PowerDVD{*}\')\nhwnds = []\ni = 0\nwhile not hwnds:\n    hwnds = findPowerDVD()\n    sleep(0.1)\n    i += 1\n    if i == 200:\n        break\nif i < 200:\n    eg.SendKeys(hwnds[0], \'{Return}\')\nelse:\n    print "Cyberlink PowerDVD not found"')
            PowerDvd.NavigationDown()
            PowerDvd.Play()
GBWebmaster
GBWebmaster wrote:Could I add the step "Navigation Down" into the script?
As I understand it, so now it works as follows:
1. The script waits at the window of PowerDVD and then sends a command to Play
2. Then follow action CyberLink PowerDVD: Navigation Down
3. Then follow action CyberLink PowerDVD: Play
If so, then you can modify the Python Script as follows:
hwnds = []
i = 0
while not hwnds:
    sleep(0.1)
    i += 1
    if i == 200:
        break
if i < 200:
    eg.SendKeys(hwnds[0], '{Down}')
and macro looks like this:
Note: It is possible that you can delete the first command Play (line eg.SendKeys(hwnds[0], '{Return}'))
GBWebmaster
Hello Pako,
thank you very, very much. Now it works great, really.
Pako wrote:Note: It is possible that you can delete the first command Play (line eg.SendKeys(hwnds[0], '{Return}'))
Yes, it is possible. The first line isn't necessary.
