View Log Dialog
jsonnabend
View Log Dialog
Post by jsonnabend »
I'm using 0.4.1r1522. Why is EG giving me a dialog every time there's an error? I'm going to end up with 100's or 1000's of dialogs if I leave EG running for any length of time. That's not good.
- Jeff
Re: View Log Dialog
1. I understand that it is not good, but I did not understand what you are talking about. Perhaps you will have to provide more information.
2. This post is more suited to the section Bug Reports
jsonnabend
Re: View Log Dialog
Pako, thanks for looking into this.
I was using the network listener plugin (that's what it's called, right?) and sending a network event from the command line (using the -n switch). The dialogs were triggered when I tried to send an event and the plugin wasn't yet initialized. I think it was still opening the network port. I don't know which instance of EG displayed the dialog, the sender or the receiver, both of which are on the same machine.
- Jeff
