several X10 receivers
Eggert
Post by Eggert »
Hey,
I use two X10 remotes on one receiver in my house.
The receiver is installed almost in the middle of the house in order to get all rooms covered.
But this does not work really good.
I'd need to get more receivers getting more reception.
But I see a problem when several receivers' areas overlap and I send one command and it is interpreted by all receivers.
A) Can I get EventGhost to work with several X10 receivers? (my 1st choice)
B) Is it better to program the X10s on different channels? (don't know if it's possible)
Thanks in advance!
Eggert
b_weijenberg
Re: several X10 receivers
Post by b_weijenberg »
Eggert,
If you use 433.92MHz European X10:
The www.rfxcom.com 11202 RFXLAN with xPL can be used in EG. You can use your current X10 receiver and simply add this RFXLAN transceiver.
With the RFXLAN you can receive X10 lighting and X10 security sensors and you can also transmit X10 lighting commands to control X10 modules and X10 security commands to control an X10 security panel with commands from EG.
In addition it allows you to receive Oregon sensors, HomeEasy, Nexa, Chacon, KlikAanKlikUit and ATI remotes.
And control HomeEasy, Nexa, Chacon, KlikAanKlikUit.
Bert
