Interpreting TIRA learned IR codes
kkl
Post by kkl »
Does anyone know how to interpret the IR codes learned by the TIRA plug-in? I thought it might be described in the Timing section of this document (http://www.home-electro.com/download/Protocol1.pdf), but I can't figure out any correlation with a real-world sample:
00 00 00 00 08 00 00 00 35 00 00 00 9D 00 00 00 EE 10 00 00 0A 2B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 34 88 5E 05 00 00 00 00 00 00 00 00 02 00 00 00 0C 00 00 00 84 67 00 00 00 00 00 00 5F 00 00 00 FF FF FF FF 00 01 00 01 00 01 01 00 00 01 00 01 00 01 01 00 00 01 00 01 00 01 00 02 00 01 00 01 00 01 01 00 00 01 00 01 00 01 01 00 00 01 00 01 00 01 00 03 00 01 00 01 00 01 01 00 00 01 00 01 00 01 01 00 00 01 00 01 00 01 00 02 00 01 00 01 00 01 01 00 00 01 00 01 00 01 01 00 00 01 00 01 00 01 00
dukey
Re: Interpreting TIRA learned IR codes
Post by dukey »
for tira learning mode i think you need to hold the remote about 1cm from the receiver. I think it uses a special learning sensor. Either that or you are using a remote with a non standard frequency, like one with 50hz
kkl
Post by kkl »
I am able to learn keys with the TIRA. I am trying to understand the format it uses in order to tweak the output for a very picky remote protocol.
