Browser forward and back buttons as actions, not events
TitaniumDust
Post by TitaniumDust »
Hi! I'll get to the point right here... I need a way of sending browser forward and browser back commands as *actions*, not events. The mouse plugin allows quite a few types of clicks but no forward or back clicks. Right now I'm just running an application which is an autohotkey compiled script sending the forward or back commands as needed. I searched this forum and did some internet searches about python but I couldn't find the answer after a couple of hours searching. (I'm clueless about python scripting)
Here's a little more info should you desire to read. :wink:
I wanted my DeathAdder mouse forward button (xbutton2) to map to both forward and sensitivity using a macro... so I set the mouse driver to macro mode, and had it type the INS key when I press and release xbutton2. If I hold down the button and scroll the wheel, that's how I change the mouse sensitivity/speed. Anyways, this works fine, and I configured eventghost to wait for INS to be pressed and then I want to send the browser forward command. I was hoping there was a more elegant solution that having to run an external application just to send a browser forward command.
Thank you!
Re: Browser forward and back buttons as actions, not events
"Emulate Keystroke" action with {BrowserBack} and {BrowserForward} seems to do the trick.
TitaniumDust
Thank you jonib! I had actually tried {Browser_Forward} at one point, I was sooooo close! Problem solved, thanks again.
